Error: Could not find core in Coresight setup
    • Error: Could not find core in Coresight setup
      I can not connect to cortex M3 processor SW DP, however using the same JLink I can connect to cortex M0 processor
      J-Link>con
      Please specify device / core. <Default>: CORTEX-M3
      Type '?' for selection dialog
      Device>cortex-m3
      Device "CORTEX-M3" selected.
      Connecting to target via SWD
      AP[0]: Skipped. Invalid implementer code read from CPUIDVal[31:24] = 0x00
      ****** Error: Could not find core in Coresight setup
      Cannot connect to target.
    • New
      What target device are you looking to connect to? Is is supported by J-Link?
      Make sure to use the exact device name when connecting to the target:
      Generic connect by specifying Cortex-M3 only might work in some cases but in some cases special handling is needed which is why it is important to specify the correct device name.
