[SOLVED] incorrect endianness format returned from JLinkGDBServer
  • [SOLVED] incorrect endianness format returned from JLinkGDBServer
    I'm currently working on a tms570lc4357zwt MCU, and I encountered some issue with the JLinkGDBServer executable.
    The mentioned MCU is a big endian target, and the latest versions of the JLinkGDBServer (version 6.50) returns the register values in little endian format.
    A detailed description of the issue is available here: youtrack.jetbrains.com/issue/CPP-17493
    After reading a thread dealing with similar symptoms (sourceware-org.1504.n7.nabble.…endian-host-td560191.html), I tried to use an older version of the software (6.22, as suggested in the thread), and I can smoothly debug my application.
    Am I missing something, or is it just a regression in your software?
    Guillaume
  • Hello Guillaume,
    We got similar requests via our support system. It should be fixed with the latest J-Link version V6.52a.
    Could you give it a try?
  • Hello Guillaume,
    Sauci wrote:
    Sorry for posting this on the forum, I was not aware of that.
    Its fine to post in the forum, I was just pointing out that we were made aware of that through other channels ;)
    Sorry for the confusion.
