Option bytes not written as expected - block verification error
    • Option bytes not written as expected - block verification error
      I am using J-Flash V6.52 for programming an STM32L151VC device.
      The data file I am trying to flash also contains the option bytes that are supposed to be written from address 0x1FF80000.
      These are the bytes shown when I open the file in J-Flash:
      00 00 FF FF EC 00 13 FF 00 00 FF FF 00 00 FF FF 00 00 FF FF 00 00 FF FF
      So with these option bytes I want to set read protection, HW independent watchdog and BOR_LEVEL5.
      When I try to program the data file I see following logging:
      Auto programming target (257804 bytes, 3 ranges) ...
      - Connecting ...
      - Connected successfully
      - Checking if selected data fits into selected flash sectors.
      - Start of preparing flash programming
      - End of preparing flash programming
      - Start of determining dirty areas in flash cache
      - End of determining dirty areas
      - CPU speed could not be measured.
      - Chip erase not supported for flash bank @ 0x08000000. Switched to sector erase
      - Start of erasing sectors
      - Blank checking 0x08000000 - 0x0801FFFF
      - Erasing range 0x08000000 - 0x0801FFFF (512 Sectors, 128 KB)
      - Blank checking 0x08020000 - 0x0803FFFF
      - Erasing range 0x08020000 - 0x0803FFFF (512 Sectors, 128 KB)
      - Blank checking 0x08080000 - 0x08081FFF
      - Erasing range 0x08080000 - 0x08081FFF ( 1 Sector, 8 KB)
      - Blank checking 0x1FF80000 - 0x1FF8001F
      - Erasing range 0x1FF80000 - 0x1FF8001F ( 1 Sector, 32 Bytes)
      - End of erasing sectors
      - Start of flash programming
      - Programming range 0x08000000 - 0x080026FF ( 39 Sectors, 9 KB)
      - Programming range 0x08003800 - 0x0800B7FF (128 Sectors, 32 KB)
      - Programming range 0x0800B800 - 0x080137FF (128 Sectors, 32 KB)
      - Programming range 0x08013800 - 0x0801B7FF (128 Sectors, 32 KB)
      - Programming range 0x0801B800 - 0x080237FF (128 Sectors, 32 KB)
      - Programming range 0x08023800 - 0x0802B7FF (128 Sectors, 32 KB)
      - Programming range 0x0802B800 - 0x080337FF (128 Sectors, 32 KB)
      - Programming range 0x08033800 - 0x0803B7FF (128 Sectors, 32 KB)
      - Programming range 0x0803B800 - 0x0803FFFF ( 72 Sectors, 18 KB)
      - Programming range 0x1FF80000 - 0x1FF8001F ( 1 Sector, 32 Bytes)
      - End of flash programming
      - Flash programming performed for 3 ranges (257824 bytes)
      - 0x8000000 - 0x80026FF ( 39 Sectors, 9 KB)
      - 0x8003800 - 0x803FFFF (968 Sectors, 242 KB)
      - 0x1FF80000 - 0x1FF8001F ( 1 Sector, 32 Bytes)
      - Start of restoring
      - ERROR: Programming failed @ address 0x1FF80000 (block verification error)
      - ERROR: Failed to restore target. RAMCode never stops
      - End of restoring
      - ERROR: Failed to auto program target
      Error: Programming failed @ address 0x1FF80000 (block verification error)
      Disconnecting ...
      - Disconnected
      So the programming fails with a block verification error on the option bytes!
      If I then do a readback of the entire chip and then look at the 0x1FF80000 range, I see following option bytes displayed:
      00 00 FF FE EC 00 13 FF 00 00 FF FF 00 00 FF FF 00 00 FF FF 00 00 FF FF
      So the 4th byte is 0xFE while it should be 0xFF instead. 0xFF is the expected complement value of 0x00, the second option byte.
      I assume that this leads to the "block verification" error.
      If a write default option bytes:
      AA 00 55 FF EC 00 13 FF 00 00 FF FF 00 00 FF FF 00 00 FF 00 00 FF FF
      Then all goes fine:
      - Connecting ...
      - End of restoring
      - Executing exit sequence ...
      - De-initialized successfully
      - Target erased, programmed and verified successfully - Completed after 8.551 sec
      Starting application ...
      - Disconnecting ...
      - Disconnected
      - J-Link firmware: J-Link V10 compiled Aug 27 2019 09:24:55
      - Device "STM32L151VC (ALLOW OPT. BYTES)" selected.
      - Found SW-DP with ID 0x2BA01477
      - Scanning AP map to find all available APs
      - AP[1]: Stopped AP scan as end of AP map has been reached
      - AP[0]: AHB-AP (IDR: 0x24770011)
      - Iterating through AP map to find AHB-AP to use
      - AP[0]: Core found
      - AP[0]: AHB-AP ROM base: 0xE00FF000
      - CPUID register: 0x412FC230. Implementer code: 0x41 (ARM)
      - Found Cortex-M3 r2p0, Little endian.
      - FPUnit: 6 code (BP) slots and 2 literal slots
      - CoreSight components:
      - ROMTbl[0] @ E00FF000
      - ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 002BB000 SCS
      - ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 002BB002 DWT
      - ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
      - ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 002BB001 ITM
      - ROMTbl[0][4]: E0040000, CID: B105900D, PID: 002BB923 TPIU-Lite
      - ROMTbl[0][5]: E0041000, CID: B105900D, PID: 002BB924 ETM-M3
      - Reset: Halt core after reset via DEMCR.VC_CORERESET.
      - Reset: Reset device via AIRCR.SYSRESETREQ.
      - Target application started
      A read back shows the option bytes as expected.
      So what went wrong here? Is setting the read protection in the option bytes causing a failure in the interaction of J-flash with the target?
      Any ideas?
      Thanks.
      Wim
    • New
      Hi Wim,
      Update:
      Unfortunately we do not have a STM32L151VC to test right now, but it should be the same procedure on every STM32L151xx,
      so I tested to set the option bytes that you provided on a STM32L151VD and STM32L151CB device and it works flawlessly.
      The only issue with a block-verification error occurred when I tried to set the read protection (RDP) back to 0xAA (Level 0) through J-Flash.
      Setting the RDP back to 0xAA through a program-operation in J-Flash is not possible because writing 0xAA into that section triggers a mass-erase of the complete flash,
      so we just ignore it in that case.
      How did you managed to set this byte back to 0xAA through a program-operation in J-Flash?
      Furthermore do you use custom hardware
      or an evaluation board? In the latter case which one?
      If custom hardware, do you experience the same problem on an
      evaluation board?
      Daniel
