[SOLVED] J-flash - flashloader exceeds max. size error
  • [SOLVED] J-flash - flashloader exceeds max. size error
    I'm using the Jflash tool with a custom flashloader created using the open flash loader tool, for the Cortex-M3 r2p1. When I open JFlash I get
    - ERROR: Specified flashloader exceeds max. size of 64 KB.
    I haven't seen this in the docs so I'm asking if anyone's seen this before.
    I have a feeling it's because the .elf file is too large because we included our own library (this must be included).
    text data bss dec hex filename
    13413 100 71952 85465 14dd9 open_flash_loader.elf
    Where does the 64KB limit come from and is it possible to increase this?
    I've been changing the FlashBankInfo-MaxSize in the JLinkDevices.xml, that doesn't seem to be it.
    Thank you
    Update:
    Updated to the latest j-link version and the error seems to have went away (was using 6.34). Now have cannot find flash struct, but that's another problem.
    The post was edited 1 time, last by fire: Update ().
    Great to hear that you could resolve the issue by yourself.
