[SOLVED] STM32 CPU in Secured state
  • [SOLVED] STM32 CPU in Secured state
    Is there any way that allows to detect secured (protected to Level 1) CPU?
    Because if I try to connect to locked CPU using J-Flash. It automatically unlocks CPU (which cause full erase of CPU contents) .
    I think this behavious is unsafe if we do not have CPU flash contents and just want to perform attepmt to read it.
    So, is there any way to detect or not erase CPU if it is secured, but just tell user "CPU is locked"?
    Many thanks
    Why would you be attempting to read it :?:
    The whole point of this protection is precisely to prevent unauthorised reading :!:
    I think this is exactly the behaviour that whoever set the protection would want to be seeing!
  • sorry, but no.
    If I sell some product of mine, I'm not sure someone could TRY to make readout of CPU flash contents.
    In fact, its not so bad. Its closed. That's all.
    But, if he or she tries to do so, it will damage contents of the FLASH! And device became unusable.
    It's done without any confirmation or smth. that tries to stop user of damaging the device.
    So, again, I tell you - this is unsafe behavior of the reading program.
    It must WARN! not DAMAGE! Feel differnce?
    I assume you run J-Flash on windows. Then you should get a pop-up asking you if you want to unsecure the detected locked device via mass erase or not.
    If you select no, no unsecure will be executed, but depending on the target device connect might also not work then.
    If you do not get such pop-up you probably selected the checkbox "don't ask again" at some point in time. That setting will be saved in registry.
    How to reset it is explained here:
    wiki.segger.com/Secured_ST_device_detected
    I hope that helps.
    As the initial question has been answered this thread will be closed now.
