[SOLVED] Segger JLink to access external SPI NOR flash on Nordic 528450 DK (pca10056) in direct mode
  • [SOLVED] Segger JLink to access external SPI NOR flash on Nordic 528450 DK (pca10056) in direct mode
    is it possible to read/write the MX25R6435F external SPI NOR flash using Indirect Mode (https://wiki.segger.com/Programming_External_SPI_Flashes) with Segger JLink?
    Currently I am getting
    1. - Start of determining flash info (Bank 1 @ 0x00000000)
    2. - ERROR: Could not find CFI compliant flash device
    3. - ERROR: Error while determining flash info (Bank 1 @ 0x00000000)
    4. - ERROR: Failed to read back target memory
    5. Disconnecting ...
    6. - J-Link: Flash download: Bank 0 @ 0x00000000: Skipped. Contents already match
    7. - Disconnected
    [/quote]According to segger.com/downloads/supported-devices.php parallel CFI NOR flash should be supported:
    NameCoreSupported flash typesNotesNordic SeminRF52840_xxAA
    Cortex-M4Parallel CFI NOR flash
    Internal flash
    Is the MX25R6435F CFI compliant?
    If I deselect automatic flash memory detection in the project settings, I cannot see the flash device:
    [img]https://devzone.nordicsemi.com/resized-image/__size/320x240/__key/support-attachments/beef5d1b77644c448dabff31668f3a47-ae42c2b26f814437bd7d77d4c9318e22/pastedimage1568961669605v1.png[/img]
    JFlash SPI, which I would use to connect the device in direct mode supports the device:
    segger.com/products/debug-prob…es/supported-spi-flashes/
    Is it possible to use the indirect mode or do I need to solder and interface directly with the flash chip?
    Markus
    J-Link currently does not offer indirect programming of SPI Flashes for that target device.
    But you can create a Flash loader for that using a open Flash Loader interface:
    wiki.segger.com/Open_Flashloader
