How to draw a GIF with Scale to IMAGE Widget and keep transparency?
    • How to draw a GIF with Scale to IMAGE Widget and keep transparency?
      Hello
      Thank you for all.
      I want to draw a scaled GIF SUB(s) Images with IMAGE widget.
      I set a Callback of IMAGE, and use GUI_GIF_DrawSubScaled at WM_Paint.
      but the Transparency of My GIF Animated has loss.
      void cbAnimation(WM_MESSAGE* pMsg)
      const tAnimation *rAnimation;
      switch (pMsg->MsgId)
      case WM_PAINT:
      GUI_GIF_DrawSubScaled(Image, Size, 0, 0, Frame, 1, 2);
      break;
      default: WM_DefaultProc(pMsg);
      hwnd= IMAGE_CreateUser(0, 0, 100, 100, 0, WM_CF_SHOW , IMAGE_CF_MEMDEV, 0, sizeof(void *));
      IMAGE_SetGIF(hwnd, Image, Size);
      (the variables are use only for explaining.)
      Also i try with Window, the result was same
      whould you send me an example for how to draw a correct scaled GIF sub Image?
      At attachment picture(s), there are two type of GIF Animated.
      Best Regards.
      Attached is a short example.
      The reason on side is most likely related to the GIF. Try to open the GIF with GIMP (or any other image editor tool) and un-optimize the GIF. Most GIFs are saved optimzed which means they store only the difference to the previous image. Unfortunately, this results in a strange output when only a sub image gets drawn.
