[SOLVED] ram placement with OS_RAM_SECTION_ATTRIBUTE define
  • [SOLVED] ram placement with OS_RAM_SECTION_ATTRIBUTE define
    Hi
    I'd like to force the placement of all embOs variable in the internal SRAM, whereas the standard placement is in the external SDRAM in my linker file.
    I try to use OS_RAM_SECTION_ATTRIBUTE define like this :
    1. #define OS_RAM_SECTION_ATTRIBUTE @ ".CPU_SRAM"
    and in the linker file :
    1. define region CPU_SRAM_region = mem:[from 0x00000000 to 0x00001FFFF];
    2. "CPU_SRAM":place in CPU_SRAM_region { section .CPU_SRAM, section .CPU_SRAM.noinit};
    It works fine for all module (embOs and others, with the same kind of syntax), but for embOs, I have some compiler warnings :
    1. variable "_InStage @ ".CPU_SRAM.init"" (declared at line 171 of "C:\Work\Soft\empty-rx-project\libs\asc-framework\Libs\embos\GenOSSrc\OS_Com.c") is an initialized variable in __data32 memory (1 more variable like this)
    2. variable "_abInBuffer @ ".CPU_SRAM.init"" (declared at line 168 of "C:\Work\Soft\empty-rx-project\libs\asc-framework\Libs\embos\GenOSSrc\OS_Com.c") is a zero-initialized variable in __data32 memory (14 more variables like
    because some varaibles are initilized with a specific, and other to 0 in the same C file.
    I'd like to know how can i suppress this warnings.
    thanks for all
    Liscence OS-01165, embOS for renesas RX, IAR compiler
