Ozone v.2.70 and C++ Lambdas
    • Ozone v.2.70 and C++ Lambdas
      I just wonder if anyone is using C++ Lambdas and Ozone ?
      I tried, but Ozone stopped with the message : "An unexpected exception occurred and Ozone needs to close."... when starting up the project.
      I had no problem compiling it using C++14/GCC++ 8.2.1, and it runs fine on the target platform Cortex-M4 Kinetis K27F (downloaded by J-Flash).
      Sample code like this :
      #define LAMBDA // Ozone v2.70 crashes with LAMBDA defined!
      #ifndef LAMBDA
      // use a function instead of lambda
      static auto outOfRange(float value, float loMin, float hiMax)
      return (value < loMin || value > hiMax);
      #endif
      void Measurement::sample()
      #ifdef LAMBDA
      // lambda function
      auto outOfRange = [] (auto value, auto loMin, auto hiMax) { return (value < loMin || value > hiMax);};
      #endif
      const auto chargeOutOfRange = outOfRange(getChargeCurrent(), maxChargeCurrentLimit() - chargeCurrentToleranseLimit(), maxChargeCurrentLimit() + chargeCurrentToleranseLimit());
      const auto dischargeOutOrRange = outOfRange(getDischargeCurrent(),minDischargeCurrentLimit(), maxDischargeCurrentLimit());
      Eldar
    • Hello Eldar,
      Could you provide an example project for reproduction that would run on an eval board?
