[SOLVED] iMXRT1050-EVKB QSPI Flash issues
  • [SOLVED] iMXRT1050-EVKB QSPI Flash issues
    Hi - I'm working on getting the iMXRT1050-EVKB NXP development board running/debugging using the QSPI flash (IS25WP064AJBLE). I've modified the EVKB hardware from the default HyperFlash to QSPI Flash. I've modified the JLinkDevices.xml to use iMXRT105x/NXP_iMXRT105x_QSPI.elf. I'm using JLink V6.50a with j-Trace Pro Cortex-M.
    Using a logic analyzer I can see that the JLink/Trace is reading/writing the QSPI flash successfully (and the data is what I expect) when it goes thru the comparison/program phase. I can see the QSPI flash being successfully read (and the data is what I expect) where the reset handler entry point code starts. However, the JLink gdb server always fails with:
    Starting target CPU...
    ERROR: Can not read register 15 (R15) while CPU is running
    Reading all registers
    ERROR: Can not read register 0 (R0) while CPU is running
    etc
    However, if I change the JLinkDevices.xml to use iMXRT102x/NXP_iMXRT102x_QSPI.elf, I can usually get it to work (usually; sometimes it seems that it fails to compare/erase properly).
    Is this an issue on my side? Any insight is appreciated. Thanks.
    -Kevin
  • Hello Kevin,
    Does the example project from our Wiki work on your board? Did you follow all steps? It has been tested with the EVK so it should be working:
    wiki.segger.com/i.MXRT1050#QSPI_Flash_2
    Did you power cycle the eval board after a failed session? iMX devices are prone to get stuck if something went wrong and only a power on reset clears the device from that state.
  • Thanks for the response.
    Actually, no, the example project doesn't work.
    I downloaded the project. I downloaded Embedded Studio. I opened the .emProject file. I built the project. Looking at the map file it doesn't seem to put any code/data in the IMXRT1050 flash memory space (starts at 0x6000 0000), only in the ITCM/DTCM.
    So I fiddled with the configuration to put things in flash memory space (Options -> Code -> Build -> Memory Segments -> FLASH1 RX 0x60000000 ...) and rebuilt.
    I changed the JLinkDevices.xml to use iMXRT105x/NXP_iMXRT105x_QSPI.elf for the MIMRT105x devices.
    I then configured to debug using jlink (Options -> Debug -> Debugger -> Target Connection -> J-Link, and Target Device -> MIMRT1052xxxx). I'm using j-Trace Pro, with a 1050EVKB target. Starting a debug session pops up a dialog with "failed to download application. undocumented error".
    Changing the JLinkDevices.xml to use iMXRT102x/NXP_iMXRT102x_QSPI.elf works - it programs the flash and stops at main().
