[SOLVED] Ozone Feature Request - Fixed point numbers
  • [SOLVED] Ozone Feature Request - Fixed point numbers
    Hi!
    I'm working on a motor control algorithm using 16.16 fixed point numbers.
    It would be nice if the "Display As" context menu could be extended to support fixed point numbers or arbitrary scaling factors.
    My current work-around is to use expression of the form "x / 65536.0" in the Watch and Data Graph window.
    But for data entry, I always have to use a calculator :/
    The approach with the expression for the watched data is currently the only available one.
    We will take your input on fixed point numbers and add it to our Ozone wishlist.
