WM_GetId of WINDOW-object is always 0
    • WM_GetId of WINDOW-object is always 0
      Hello.
      If create a window by WINDOW_CreateEx with some non-zero id for this window, so WM_GetId returns always 0.
      1. WM_HWIN hWin = WINDOW_CreateEx(0, 0, 100, 100, WM_HBKWIN, WM_CF_SHOW, 0, 1234, 0);
      2. int id = WM_GetId(hWin);
      Is it bug?
      For other widgets, including FRAMEWIN-widget it returns correct value.
      Why you use type int for Id as parameter in all functions, although in fact the real Id-data is only I16 (short)?
      1. typedef struct {
      2. WM_Obj Win;
      3. const WIDGET_EFFECT* pEffect;
      4. I16 Id;
      5. U16 State;
      6. } WIDGET;
      It's very pity that full 32-bit int is not used for Id.
      Volodymyr.
