[SOLVED] Can't connect to Silicon Labs EFR32MG21A010F1024
  • [SOLVED] Can't connect to Silicon Labs EFR32MG21A010F1024
    I have problem with connecting to the EFR32MG21A010F1024 device on my own custom board. The board consist(at this time) of the EFR32 MCU, the decoupling capacitors and nothing else. I am using the J-link software pack v6.48b and the J-Link PLUS hardware. I try to use the J-Flash utility and after running the Target/Connect command I obtain an error:
    Connecting ...
    - J-Link firmware: J-Link V10 compiled Jul 23 2019 13:46:10
    - Device "EFR32MG21AXXXF1024" selected.
    - Found SW-DP with ID 0x6BA02477
    - Scanning AP map to find all available APs
    - AP[3]: Stopped AP scan as end of AP map has been reached
    - AP[0]: AHB-AP (IDR: 0x84770001)
    - AP[1]: APB-AP (IDR: 0x54770002)
    - AP[2]: AHB-AP (IDR: 0x84770001)
    - Iterating through AP map to find AHB-AP to use
    - AP[0]: Skipped. Invalid implementer code read from CPUIDVal[31:24] = 0x00
    - AP[1]: Skipped. Not an AHB-AP
    - AP[2]: Skipped. Invalid implementer code read from CPUIDVal[31:24] = 0x00
    - Target interface speed: 200 kHz (Auto)
    - VTarget = 3.135V
    - ERROR: Could not find core in Coresight setup
    - ERROR: Failed to connect.
    Could not establish a connection to target.
    When I try to use the J-Link Commander I am also not able to connect to the EFR32 device and read the flash content. The commander window contain:
    SEGGER J-Link Commander V6.48b (Compiled Aug 2 2019 10:19:19)
    DLL version V6.48b, compiled Aug 2 2019 10:18:25
    Firmware: J-Link V10 compiled Jul 23 2019 13:46:10
    Hardware version: V10.10
    S/N: 600113010
    VTref=3.145V
    J-Link>usb 0
    Disconnecting from J-Link...O.K.
    S/N: 600113010
    VTref=3.148V
    J-Link>mem 0x0 200
    Target connection not established yet but required for command.
    Please specify device / core. <Default>: EFR32MG21AXXXF1024
    Type '?' for selection dialog
    Device>
    J) JTAG (Default)
    S) SWD
    T) cJTAG
    TIF>s
    Speed>
    Connecting to target via SWD
    ****** Error: Could not find core in Coresight setup
    Cannot connect to target.
    Where can be the problem with the connecting? The communication across the SWDIO and SWCLK works, because some AHB-AP's has been found...
    Does the Segger software 6.48b ability to connect to the EFR32MG21A010F1024?
    Thank you for your response!
    milanatik
    We gave it a try on an BRD4181A Evalboard on a PCB4001 base board and everything is working as expected with J-Link software V6.50b.
    Could you try the latest J-Link software version?
    Could you check if you see the same behaviour with an eval board?
    If not we recommend using the eval board design as base for your custom board design.
