Flash Loader Failure when external flash is accessed
    • Flash Loader Failure when external flash is accessed
      I'm using j-link in order to program my STM32H743 device via IAR IDE.
      I'm using extened ex-flash (winbond W25Q128JV) with QSPI interface.
      In my code, I defined an image with an address on the external flash.
      __root const unsigned char _acImage_01_16bit565[109512UL+ 1] [b]@ 0x90000000[/b]
      When I try to program the device I get the following error window (see attached).
      Tue Aug 27, 2019 12:53:14: Flash download warning: 109513 out of 109513 bytes from data record CODE:[0x90000000,0x9001ABC8] will not be flashed
      Tue Aug 27, 2019 12:53:14: There were warnings while generating flash loader input.
      Do you have any suggestions for programming the device (including the external flash)? I checked the J-Flash tool, but I could not program it right.
      If I need to create my own flash loader can you please advice on how to do it?
      For the STM32H743 external QSPI Flash is currently not supported.
      But you can add support yourself by using our open Flash loader interface.
      wiki.segger.com/Open_Flashloader
      Alternatively we can do it for your, in that case NREs would apply.
      Would that generally be of interest for you?
      Sysmop226 wrote:
      For opening and supporting a new device, I need a flash loader, which flash loader can I use?
      STMF7 flash loader would match?
      STM32F7 is not compatible to STM32H7. You would need to write a new Flash loader as explained in the Wiki. Or we can do it for your for NREs.
