If I get you right you want to make sure that the initial dialog (the one with _cbDialog) don't receive input when the derived dialog is created (_cbDerivedDialog), right?
To achieve that you can simply make the derived dialog modal:
- static void _cbDerivedDialog(WM_MESSAGE * pMsg) {
- WM_HWIN hItem;
- int NCode;
- int Id;
- WM_KEY_INFO * pInfo = (WM_KEY_INFO *)pMsg->Data.p;
- switch (pMsg->MsgId) {
- case WM_INIT_DIALOG:
- setupDropdown(WM_GetDialogItem(pMsg->hWin, ID_DERIVED_DROPDOWN_0));
- WM_MakeModal(pMsg->hWin);
- break;
- case WM_NOTIFY_PARENT:
- switch (pMsg->Data.v) {
- case WM_NOTIFICATION_RELEASED:
- switch (WM_GetId(pMsg->hWinSrc)) {
- case ID_DERIVED_BUTTON_0:
- GUI_EndDialog(pMsg->hWin, 0);
- isUntouched = 0;
- break;
- break;
- break;
- default:
- WM_DefaultProc(pMsg);
- break;
