[SOLVED] Include unlock command in Flasher ARM
  • [SOLVED] Include unlock command in Flasher ARM
    Some production batches have boards which were previously programmed with 'allow security'. When I manually re-program these using J-Link Commander, I need to use the 'unlock kinetis' command before loading the file. How do I ensure that these can be successfully re-programmed with a stand-alone Flasher ARM?
    Denis
