Create a new solution containing other SES projects
    • Create a new solution containing other SES projects
      Hi Nino and fellow developers,
      I have been working on two applications and now I want to combine both these projects in one solution so I can debug together; first application being a bootloader and the second being our runtime application.
      I create a new "empty solution"; right click add existing project and add in the two projects. My project explorer seems to show these now as a top level solution containing two solutions each containing a project. See attachment.
      I now try and build the two applications; both builds fail.
      I then look into the two projects from the IDE; and I see different options as when the projects were individually built in their own solutions.
      The bootloader fails to build as it is too big; I check the optimisation level and it has changed from "optimise for size" to "none"; if I try and modify this setting it appears to be locked to "none".
      This appears to be an issue with inherited settings/configuration.
      How do I achieve what I want to do?
      Is there a recommended way?
      Kind Regards,
      Owain
      To make sure we understand you correctly here, is everything working now?
