[ABANDONED] Window/desktop layout
    Everytime you close Embedded Studio for the last open project an .emSession file will be created which saves all current window positions etc.
    If you load the corresponding .emProject file next time in SES the settings from the .emSession file will be applied.
    Is that what you were looking for?
  • I just tried an experiment:
    I opened 2 different .emProjects (different names, in different directories), in separate instances of SES.
    I moved a window in one, then closed both.
    It seems the window layout always returns to the one from the last closed instance.
    The emSession file will be update once a solution/project is closed or Embedded Studio is closed.
