Breakpoint opens wrong source file
    • Breakpoint opens wrong source file
      I am using SES V4.18 Windows X64.
      The system I am developing has a Transmitter and a Receiver device. They share a lot of code (at a source code level only).
      I have the Receiver project open, compile the code, download it and set a breakpoint in some place.
      However, when the breakpoint hits, the source browser opens the wrong source .c file -- one that is not even included in this project, but is in the other project.
      The disassembler panel shows the correct code and line numbers (for the correct file), but I can't step through in the source code panel.
      Any idea what's going wrong?
      From the error description it seems that symbol information might be missing from the application.
      Do you have some optimization level enabled for your project?
      Could you provide an example project for reproduction purposes?
      Do you get the same behaviour when debugging with Ozone?
      segger.com/products/development-tools/ozone-j-link-debugger/
    • If it helps, the problem files are called:
      HT4_USB_Commands.c (the correct file)
      HT4_Rx_Commands.c (the incorrect file, that is not even included in the Project)
      If I rename HT4_Rx_Commands.c to HT4_Rx_Cmds.c, the problem goes away.
      Surely the IDE can distinguish between the 2 original file names?
      Usually yes, which is why I wrote that the issue is not known to us.
      Could you answer my remaining questions?
