[SOLVED] Segger Free Running Zero Initial Timestamps
  • [SOLVED] Segger Free Running Zero Initial Timestamps
    When I run Segger SystemView in free running mode with an STM32F446RE NUCLEO board, I get zero timestamps until the RTT buffer overflows, and then I look to be getting meaningful timestamps (see attached screenshots). What could be the issue?
    Did you follow the integration guide in the SystemView Manual?
    Additional information can be found here:
    wiki.segger.com/FreeRTOS_with_SystemView
    That is all that should be needed to enable SystemView in your application.
