[SOLVED] Systemview-Installation fails on Linux
  • [SOLVED] Systemview-Installation fails on Linux
    i tried to install SystemView (systemview_2.52.4_x86_64.deb) on XUbuntu (new installation).
    Ozone installed fine.
    $/opt/SEGGER/SystemView/SystemView
    opt/SEGGER/SystemView/SystemView: error while loading shared libraries: libQtGui.so.4: cannot open shared object file: No such file or directory
    $ldd /opt/SEGGER/SystemView/SystemView
    linux-vdso.so.1 (0x00007ffe2efae000)
    libQtGui.so.4 => not found
    libQtCore.so.4 => not found
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f7616a2e000)
    libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f76166a5000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f7616307000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f76160ef000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f7615cfe000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f7615af6000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f76158f2000)
    /lib64/ld-linux-x86-64.so.2 (0x00007f7616c4d000)
    $ ldd /opt/SEGGER/ozone/2.62.7/Ozone
    linux-vdso.so.1 (0x00007fffed4f3000)
    libjlinkarm.so.6 => /opt/SEGGER/ozone/2.62.7/Lib/libjlinkarm.so.6 (0x00007f36ec911000)
    libQtWebKit.so.4 => /opt/SEGGER/ozone/2.62.7/Lib/libQtWebKit.so.4 (0x00007f36eaca5000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f36eaaa1000)
    libQtGui.so.4 => /opt/SEGGER/ozone/2.62.7/Lib/libQtGui.so.4 (0x00007f36e9d9d000)
    libQtCore.so.4 => /opt/SEGGER/ozone/2.62.7/Lib/libQtCore.so.4 (0x00007f36e9888000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f36e9669000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f36e92cb000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f36e90b3000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f36e8cc2000)
    /lib64/ld-linux-x86-64.so.2 (0x00007f36ede98000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f36e8aba000)
    libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f36e8731000)
    libX11.so.6 => /usr/lib/x86_64-linux-gnu/libX11.so.6 (0x00007f36e83f9000)
    libXrender.so.1 => /usr/lib/x86_64-linux-gnu/libXrender.so.1 (0x00007f36e81ef000)
    libQtNetwork.so.4 => /opt/SEGGER/ozone/2.62.7/Lib/libQtNetwork.so.4 (0x00007f36e7ec6000)
    libfreetype.so.6 => /usr/lib/x86_64-linux-gnu/libfreetype.so.6 (0x00007f36e7c12000)
    libfontconfig.so.1 => /usr/lib/x86_64-linux-gnu/libfontconfig.so.1 (0x00007f36e79cd000)
    libXext.so.6 => /usr/lib/x86_64-linux-gnu/libXext.so.6 (0x00007f36e77bb000)
    libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f36e7593000)
    libpng16.so.16 => /usr/lib/x86_64-linux-gnu/libpng16.so.16 (0x00007f36e7361000)
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f36e7144000)
    libexpat.so.1 => /lib/x86_64-linux-gnu/libexpat.so.1 (0x00007f36e6f12000)
    libXau.so.6 => /usr/lib/x86_64-linux-gnu/libXau.so.6 (0x00007f36e6d0e000)
    libXdmcp.so.6 => /usr/lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007f36e6b08000)
    libbsd.so.0 => /lib/x86_64-linux-gnu/libbsd.so.0 (0x00007f36e68f3000)
    Why does ozone install libQtQui.so.4 fine and SystemView not?
    How can i fix this?
    Thanks!
    You can fix this by installing the missing libraries or using a Linux that has them per default e.g. Ubuntu 16.04 LTS or 18.04 LTS.
    It is currently not being shipped with SystemView as SystemView is currently being revampt. So future versions of SystemView should ship with all needed libraries even if not provided by the OS.
  • Hi Nino,
    thank you for this answer.
    So i just copied:
    sudo cp ../ozone/2.62.7/Lib/libQtCore.so.4 /usr/lib/
    sudo cp ../ozone/2.62.7/Lib/libQtGui.so.4 /usr/lib/
    Now the libs are accessible, but i get a new error message:
    SystemView: symbol lookup error: SystemView: undefined symbol: _ZN12QApplication13setMainWidgetEP7QWidget
    Now, i have no idea how to solve this.
    Thank you.
  • siermm wrote:
    Hi Nino,
    So i just copied:
    Thank you.
    May be this can help (my old thread: ) forum.segger.com/index.php/Thr…-rpm-is-a-broken-install/
    How can i fix this?
    Thanks!
    If there is a need, I can provide a pre-configured /setup & tested Linux VM machine with all Segger tools installed & running.
    Ready for full dev work.
    Can message me.
