Some Keys not working correctly with NEO2 Keyboard Layout
    • Some Keys not working correctly with NEO2 Keyboard Layout
      im using Windows with NEO2 Keyboard Layout.
      Now i noticed that is Segger Embedded Studio some Keys are not working properly.
      I have Problems with STRG-C/V/X (maby others too) and all special characters in the third layer.
      So i have to press }{)(><-"';:& and so on twice!! Thats really bad for programming... :(
      Is there a solution for that other than switching back to QWERTZ Layout?
      thanks,
      regards Philipp
    • Hello Phillip,
      Currently there are no plans to add keyboard layout support for other layouts than the ones supported by the corresponding OS.
    • SEGGER - Nino wrote:
      Hello Phillip,
      Neo2 is supported by the OS. Its only an alternative Keyboard Layout which has to be installed.
      It works in all other apps correctly, but not in SES.
      best regards,
      philipp
    • Hello Phillip,
      Yes, so it is the other way around, Neo2 supports the OS. Otherwise the layout would be shipped per default with the OS and supported by the OS vendor. This is not the case.
      It worked for applications that you tested. Embedded Studio simply uses the OS's IO interface and the keyboard layouts provided by the OS do all work.
      This leads to the conclusion that Neo2 is implementing something non standard or is buggy under certain circumstances. As we did not write the Neo2 keyboard layout we suggest getting in contact with the Neo2 support team.
    • New
      ok, i have solved the problem now and write here if others have the same problem.
      I talked to neo2 guys in IRC and the problem here is with QT. So the problem should exist on other QT apps as well.
      The solution is to use the QUERTZ driver and install neo2 with stand alone AHK script. The Autohotkey translates QUERTZ to neo2 and then everything is working correctly.
      best regards
      philipp
