SEGGER J-Link GDB Server V6.34c - Terminal output channel Connection closed by the GDB server.
    • SEGGER J-Link GDB Server V6.34c - Terminal output channel Connection closed by the GDB server.
      I am getting this error message, only after using breakpoints. I have swapped debuggers but no joy. This just started out of the blue. Any help will be appreciated.
      Connecting to J-Link...
      J-Link is connected.
      Firmware: J-Link V10 compiled Aug 23 2018 09:46:11
      Hardware: V10.10
      S/N: 50115113
      Feature(s): GDB
      Checking target voltage...
      Target voltage: 3.26 V
      Listening on TCP/IP port 2331
      Connecting to target...Connected to target
      Reading all registers
      Read 4 bytes @ address 0x000074FE (Data = 0x4807E7FD)
      Read 2 bytes @ address 0x000074FE (Data = 0xE7FD)
      Received monitor command: speed 1000
      Target interface speed set to 1000 kHz
      Received monitor command: speed auto
      Select auto target interface speed (2000 kHz)
      Received monitor command: flash breakpoints 0
      Flash breakpoints disabled
      Read 4 bytes @ address 0x00001FC0 (Data = 0x00000000)
      Read 4 bytes @ address 0x00001FC4 (Data = 0x002D0403)
      Read 4 bytes @ address 0x00001FC8 (Data = 0x00000000)
      Read 4 bytes @ address 0x00001FCC (Data = 0xB24397BA)
      GDB closed TCP/IP connection
      The J-Link software version you are using is a couple of months old. Could you give the latest software version a try?
      segger.com/downloads/jlink/#J-…twareAndDocumentationPack
      Does that solve the issue?
      Could you provide a J-Link log of the session?
      You write that it started out of the blue. Did you change anything in your setup? Other cables, other USB input, other host PC, firewalls etc.?
