How to trim leading zeros in spinbox?
    • How to trim leading zeros in spinbox?
      Is there any way to remove the leading zero in spinbox? For example, if I set the Min and Max of a spinbox as 10 and 100, then when I input the value '24' , the spinbox displays '024'. How can I remove the leading zero? Thank you.
      Try the code below. First get the EDIT handle from the SPINBOX and then modify the EDIT widget. Although it is not documented, you can pass the flag GUI_EDIT_SUPRESS_LEADING_ZEROES to the function EDIT_SetDecMode(). I will update the manual.
      1. hSpinbox = SPINBOX_CreateEx(10, 10, 80, 20, WM_HBKWIN, WM_CF_SHOW, GUI_ID_SPINBOX0, 10, 100);
      2. hEdit = SPINBOX_GetEditHandle(hSpinbox);
      3. EDIT_SetDecMode(hEdit, 10, 10, 100, 0, GUI_EDIT_SUPPRESS_LEADING_ZEROES);
