RTT unstable
    • RTT unstable
      I'm trying to use the RTT tool, but don't have a good experience. The code I'm using is the Menu example provides by SEGGER, all enviroment is using Windows 10.
      I can make RTT communication work if I do the follow steps:
      1. Turn off the development board(ADuCM3029)
      2. Shutdown J-LINK GDB server
      3. Shutdown J-LINK RTT Viewer
      4. Turn on development board
      5. Run J-LINK GDB server
      6. Run J-LINK RTT Viewer using "Exisiting connection" option
      7. Build and run debug with Cross Core application from Analog Device
      This way I can sometimes connect at first Debug session or second, sometimes doesn't work and I need to restart the steps.
      If RTT communication works, I can't run another debug session withou break the communication, so I need to restart the steps.
      Above is my GDB configurations, used when run a debug session using CCES:
      1. Initialization commands:
      2. monitor flash device = ADuCM3029
      3. monitor semihosting enable
      4. monitor semihosting breakOnError
      5. monitor semihosting IOclient 3
      6. monitor exec SetRTTSearchRanges 0x60000000 0x1000, 0x20000000 0x1000
      7. monitor flash download=1
      8. monitor clrbp
      9. monitor endian little
      10. monitor reset
      11. monitor sleep 10
      12. monitor speed auto
      13. Run commands:
      14. monitor reg r13 = (0x00000000)
      15. monitor reg pc = (0x00000004)
      16. break main
      17. continue
      So, I want to know if there is a way I can start RTT communication and doesn't need to restart the entire system.
