Data Breakpoint expressions
    • Data Breakpoint expressions
      I'm debugging my application for nrf52840 and trying to use a data breakpoint mechanism. But faced with some not understanding.
      I want the breakpoint to work according to the condition “the value of the variable is greater than” and I write the following expression:
      my_variable > 0xfe
      and it's not work. A breakpoints isn't active in breakpoints window.
      but another expression my_variable == 0xfe is worked.
      What am I doing wrong when describing a condition? I did everything according to the documentation (Embedded Studio for ARM Reference Manual, Breakpoint expressions).
      I use SES v4.18.
      p.s my_variable - it's uint32_t varible
      thanks,
      This behaviour is expected as Cortex-M targets only support data breakpoints with masked conditions e.g. ==.
      So this is unfortunately a limitation of the target device you are using as explained in the Embedded Studio manual.
