​Can emWin achieve dynamic change of two layers (layer0/layer1) at the same time
    • ​Can emWin achieve dynamic change of two layers (layer0/layer1) at the same time
      Can emWin achieve dynamic change of two layers (layer0/layer1) at the same time (1280*480)? Layer1 needs to use a memory device, but the part of the memory device I tested was not transparent.
      I'm not sure what exactly do you mean by "dynamic change of two layers".
      You can define multiple layers and these can be managed simultaneously. you can select a layer for the next drawing routines by calling GUI_SelectLayer(LayerIndex).
      A window can also be created on a dedicated layer, so its output will just be visible on "its" layer.
