OZone wish
    • Hello.
      A very usefully missed feature for OZone is:
      Export or copy (selected) watched data to a txt/csv-file or to clipboard.
      This is helpfull, if we can't use the segger_rtt to print the data by program.
      So we can copy/export a data-struct or especialy a large array of data from the Watched Data window,
      and analyze/filter the data with a external tool.
      Many thanks.
      Ozone offers the functionality called data graph that enables you to sample a symbol at a given rate and plot it over time. Then you can simply export the data to csv.
      Simply right click your watched data and select "Graph" in the context menu.
      More information can be found in the Ozone manual.
      A stand alone version of that feature would be our tool J-Scope:
      segger.com/products/debug-probes/j-link/tools/j-scope/
    • Many thanks for the reply.
      That can be a sollution for one or two variables. Correct....
      But it is not working / applicable for a big data array:
      Example: uint16_t g_debug_current[50][256]
      Do i have to pull every 12800 elements.... element by element... in a graph, do my test, export this element to a csv (g_debug_curr_1.csv, ... , g_debug_curr_4793.csv, g_debug_curr_4794.csv, ... , g_debug_curr_12799.csv, ?
      -> Than i need 20 working day's for every test :(
      A export possibility for the data will be a good feature :)
      The post was edited 2 times, last by Forster ().
      Thank you for clarifying your use case. We see your point and will add this to our wishlist for Ozone.
