Cannot select the correct Kinetis target in a JTAG chain
    • Cannot select the correct Kinetis target in a JTAG chain
      Hi!
      I have a taunting issue using a J-Link and J-Flash, regarding targeting a specific device in a chain.
      While using the IDE (EWARM 7.80.4) there are no issues, the IDE can correctly select TAP 0 or 1.
      However, for production loading, either via J-link or J-Flash, only TAP 0 (the same as auto detection selects) gets selected.
      I've tried all kinds of remedies and tips from this forum and others with no real success.
      Using J-Flash:
      All devices are correctly detected, however, selecting device 1 and flashing, results in device 0 getting flashed.
      J-flash log:
      J-Link firmware: J-Link ARM-Pro V1.x compiled Dec 3 2013 14:20:30
      Device "MK66FN2M0XXX18" selected.
      InitTarget()
      TotalIRLen = 8, IRPrint = 0x0011
      JTAG chain detection found 2 devices:
      #0 Id: 0x4BA00477, IRLen: 04, CoreSight JTAG-DP
      #1 Id: 0x4BA00477, IRLen: 04, CoreSight JTAG-DP
      AP[2]: Stopped AP scan as end of AP map has been reached
      AP[1]: JTAG-AP (IDR: 0x001C0000)
      AP[0]: Core found
      CoreSight components:
      ROMTbl[0] @ E00FF000
      ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
      ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
      ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
      ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
      ROMTbl[0][6]: E0042000, CID: B105900D, PID: 003BB907 ETB
      ROMTbl[0][7]: E0043000, CID: B105900D, PID: 001BB908 CSTF
      See jflash_tap1 for the j-flash device configuration.
      J-link:
      I've also tried to target a specific device with the jtagconf command, and had no success there either.
      jlink -if jtag -jtagconf 4,1 -autoconnect 0 -device MK66FN2M0XXX18 -speed auto
      SEGGER J-Link Commander V6.46g (Compiled Jun 14 2019 19:34:42)
      DLL version V6.46g, compiled Jun 14 2019 19:33:33
      Firmware: J-Link ARM-Pro V1.x compiled Dec 3 2013 14:20:30
      Hardware version: V1.10
      S/N: 171100199
      IP-Addr: DHCP (no addr. received yet)
      VTref=3.332V
      J-Link>h
      Target connection not established yet but required for command.
      Connecting to target via JTAG
      InitTarget()
      AP[0]: Core found
      Cortex-M4 identified.
      PC = 00007420, CycleCnt = E9AA7ACB
      R0 = 20011960, R1 = 0000000F, R2 = 20011960, R3 = 00000000
      R4 = 00000007, R5 = 2000BFE4, R6 = 00000000, R7 = 07070707
      R8 = 08080808, R9 = 09090909, R10= 10101010, R11= 11111111
      R12= 12121212
      SP(R13)= 20013098, MSP= 20013098, PSP= 20004A28, R14(LR) = 000077A5
      XPSR = 0100000F: APSR = nzcvq, EPSR = 01000000, IPSR = 00F (INTISR0)
      CFBP = 00000000, CONTROL = 00, FAULTMASK = 00, BASEPRI = 00, PRIMASK = 00
      FPS0 = 00000138, FPS1 = 48960000, FPS2 = 00000000, FPS3 = 00000000
      FPS4 = 00000000, FPS5 = 00000000, FPS6 = 00000000, FPS7 = 00000000
      FPS8 = 00000000, FPS9 = 00000000, FPS10= 00000000, FPS11= 00000000
      FPS12= 00000000, FPS13= 00000000, FPS14= 00000000, FPS15= 00000000
      FPS16= 00000000, FPS17= 00000000, FPS18= 00000000, FPS19= 00000000
      FPS20= 00000000, FPS21= 00000000, FPS22= 00000000, FPS23= 00000000
      FPS24= 00000000, FPS25= 00000000, FPS26= 00000000, FPS27= 00000000
      FPS28= 00000000, FPS29= 00000000, FPS30= 00000000, FPS31= 00000000
      FPSCR= 02000010
      This also connects to TAP 0 instead of 1.
      I've also tried all kinds of different jtagconf parameters, all of them connect to TAP 0 ?(
      Both of my MCUs have a status LED, in each case the LED of MCU 0 stops flashing.
      Any ideas?
      Which J-Link software version are you using?
      Could you give the latest version a try?
      segger.com/downloads/jlink/#J-…twareAndDocumentationPack
      The J-Link you are using is out of support for 7 years now and out of maintenance for more than 6.
      We recommend upgrading that device to a newer version.
      For this we offer a trade in program:
      segger.com/purchase/trade-in-program/
