Hi
I have a J-Link for Arm 8.0 and I'm trying to flash an MSP432 with 1MB internal flash (MSP432P411Y).
The J-Link drivers are v6.44h.
If I try to program the chip with UniFlash from TI or with IAR Embedded Workbench (meaning, only image download without debugging), the tools report a programming failure. It seems that only the first 512KB can be programmed. Addresses above this limit cannot be programmed.
If instead of using the J-Link I use a TI MSP-FET debugger, everything works fine with the same image.
I guess there is a problem in the J-Link drivers that prevents the image to be flashed.
Any help would be very appreciated.
Regards.
Regards.
