Debug mode license error
    • Debug mode license error
      Hi All,
      I'm using floating license for my KEIL IDE and NRF controller.
      I'm able to compile and run the code from KEIL but I'm not able to work in debug mode. I'm getting "Error: *** License Mapping Failed! *** Debugger aborted !" this error.
      My Jlink version version is 6.46d and windows 10 OS
      Here is the build output:
      Target info:
      Device: nRF52840_xxAA
      VTarget = 3.300V
      State of Pins:
      TCK: 0, TDI: 1, TDO: 1, TMS: 1, TRES: 1, TRST: 1
      Hardware-Breakpoints: 6
      Software-Breakpoints: 8192
      Watchpoints: 4
      JTAG speed: 1000 kHz
      Full Chip Erase Done.
      Programming Done.
      Verify OK.
      * JLink Info: Reset: Halt core after reset via DEMCR.VC_CORERESET.
      * JLink Info: Reset: Reset device via AIRCR.SYSRESETREQ.
      Application running ...
      Flash Load finished at 17:43:28
      Can anyone help me to fix this issue.
      Thanks in advance,
      Domneck
    • New
      Such an error is not known in our sourcebase so it is most likely coming out of Keil.
      You can verify this by enabling the J-Link log:
      There all error messages from J-Link software are logged.
