Hello, I'm using STM32L031 and I wish I could use jlink plus as a production tool.
I manage to program my device with JFlash in less than 2s (erase + program / Verify), but it takes 35s when using jlink.exe. I've read it could be a matter of vtref, but it would also affect JFlash.
The command line used is
the Command file is
Log file is
the Command file is
Log file is
[code]T7104 000:382 SEGGER J-Link V5.12f Log File (0001ms, 0379ms total)
T7104 000:382 DLL Compiled: May 17 2016 16:03:35 (0001ms, 0379ms total)
T7104 000:382 Logging started @ 2019-06-11 09:31 (0001ms, 0379ms total)
T7104 000:383 JLINK_SetSpeed(4000) (0000ms, 0379ms total)
T7104 000:386 JLINK_SetResetDelay(0) (0000ms, 0379ms total)
T7104 000:386 JLINK_Reset() -- CPU_ReadMem(4 bytes @ 0x20000000) -- CPU_WriteMem(4 bytes @ 0x20000000) -- CPU is running...
T7104 000:403 JLINK_SetSpeed(4000) (0000ms, 0395ms total)
T7104 000:403 JLINK_IsHalted() returns TRUE (0000ms, 0395ms total)
T7104 000:404 JLINK_EraseChip() ... -- Total time needed: 11.142s (Prepare: 0.266s, Compare: 0.000s, Erase: 0.863s, Program: 0.000s, Verify: 0.000s, Restore: 10.011s) returns 0 (11146ms, 11541ms total)
T7104 011:552 JLINK_IsHalted() returns TRUE (0000ms, 11541ms total)
T7104 011:552 JLINK_DownloadFile()JLINK_BeginDownload(Flags = 0x00) (0002ms, 11543ms total)
T7104 011:552 JLINK_WriteMem(0x08000000, 0x2610 Bytes, ...) - Data: 10 06 00 20 D5 00 00 08 69 17 00 08 DB 14 00 08 ... returns 0x2610 (0003ms, 11544ms total)
T7104 011:552 JLINK_EndDownload() -- CPU is running at low speed (4193 kHz). -- CPU is running at 4193 kHz. ... -- All CRCs match -- Comparing ... -- All CRCs match -- End of comparing flash ***** Error: Verification failed @ address 0x08000000 -- End of verifying flash -- Start of restoring -- Restore RAMCode -- Total time needed: 23.809s (Prepare: 0.069s, Compare: 20.103s, Erase: 0.068s, Program: 0.545s, Verify: 0.000s, Restore: 3.021s)
***** Error: Verification failed @ address 0x08000000 returns 0xFFFFFFFC (23817ms, 35358ms total)
T7104 011:552 returns 0xFFFFFEF5 (23817ms, 35358ms total)
T7104 035:371 JLINK_SetResetDelay(0) (0000ms, 35358ms total)
T7104 035:371 JLINK_Reset()
T7104 035:388 JLINK_GoEx(MaxEmulInsts = 0, Flags = 0x01) -- CPU_ReadMem(4 bytes @ 0xE0001000) -- CPU_WriteMem(4 bytes @ 0xE0001000) -- CPU_WriteMem(4 bytes @ 0xE0001004) (0001ms, 35376ms total)
T7104 035:389 JLINK_IsOpen() returns 0x01 (0000ms, 35376ms total)
T7104 035:412 JLINK_Close() >0x42 TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> (0002ms, 35378ms total)
T7104 035:412 (0002ms, 35378ms total)
T7104 035:412 Closed (0002ms, 35378ms total)[/code]
