misalignment of radio button
    • misalignment of radio button
      Hi all,
      I have a LCD display of size 320*240. i have one window which is having 11 radio button . I have to refresh the window whenever change is happened not from touch but based on some settings so i am calling refresh screen where i will delete the swipelist window and create again.
      Since i have to maintain the position even after refreshing the window so i am calling SWIPELIST_GetScrollPos for getting the position and SWIPELIST_GetScrollPos for setting the position after creating the swipelist but the problem is that when scroll position is more than -245 there is a position change in radio button. What i found is that this radio button which is coming in wrong position is related to the item just above the First item i.e 6. Any idea why it is happening.?
    • New
      I don't have any issues regarding misalignment.
      Here is my code:
      1. #include "DIALOG.h"
      2. #include <stdio.h>
      3. /*********************************************************************
      4. *
      5. * Externals
      6. *
      7. **********************************************************************
      8. */
      9. /*********************************************************************
      10. *
      11. * Types
      12. *
      13. **********************************************************************
      14. */
      15. /*********************************************************************
      16. *
      17. * Defines
      18. *
      19. **********************************************************************
      20. */
      21. #define ID_CHECKBOX_0 (WM_USER + 0x00)
      22. #define ID_CHECKBOX_99 (WM_USER + 0x63)
      23. #define NUM_BOXES 100
      24. /*********************************************************************
      25. *
      26. * Static data
      27. *
      28. **********************************************************************
      29. */
      30. /*********************************************************************
      31. *
      32. * Static code
      33. *
      34. **********************************************************************
      35. */
      36. /*********************************************************************
      37. *
      38. * _UncheckBoxes
      39. */
      40. static void _UncheckBoxes(WM_HWIN hParent, int Id) {
      41. int i;
      42. WM_HWIN hItem;
      43. for (i = 0; i < NUM_BOXES; i++) {
      44. if (ID_CHECKBOX_0 + i == Id) {
      45. continue;
      46. }
      47. hItem = WM_GetDialogItem(hParent, ID_CHECKBOX_0 + i);
      48. CHECKBOX_SetState(hItem, 0);
      49. }
      50. }
      51. /*********************************************************************
      52. *
      53. * _cbSwipeList
      54. */
      55. static void _cbSwipeList(WM_MESSAGE * pMsg) {
      56. int Id;
      57. int NCode;
      58. switch (pMsg->MsgId) {
      59. case WM_NOTIFY_PARENT:
      60. Id = WM_GetId(pMsg->hWinSrc);
      61. NCode = pMsg->Data.v;
      62. if (Id >= ID_CHECKBOX_0 && Id <= ID_CHECKBOX_99) {
      63. if (NCode == WM_NOTIFICATION_CLICKED) {
      64. _UncheckBoxes(pMsg->hWin, Id);
      65. }
      66. }
      67. break;
      68. default:
      69. SWIPELIST_Callback(pMsg);
      70. break;
      71. }
      72. }
      73. /*********************************************************************
      74. *
      75. * _cbCheckbox
      76. */
      77. static void _cbCheckbox(WM_MESSAGE * pMsg) {
      78. int xSize;
      79. int ySize;
      80. switch (pMsg->MsgId) {
      81. case WM_PAINT:
      82. xSize = WM_GetWindowSizeX(pMsg->hWin);
      83. ySize = WM_GetWindowSizeY(pMsg->hWin);
      84. GUI_SetColor(GUI_WHITE);
      85. GUI_SetPenSize(2);
      86. GUI_AA_DrawCircle(xSize / 2, ySize / 2, xSize / 2 - 3);
      87. if (CHECKBOX_GetState(pMsg->hWin) == 1) {
      88. GUI_AA_FillCircle(xSize / 2, ySize / 2, xSize / 2 - 6);
      89. }
      90. break;
      91. default:
      92. CHECKBOX_Callback(pMsg);
      93. break;
      94. }
      95. }
      96. /*********************************************************************
      97. *
      98. * _cbBk
      99. */
      100. static void _cbBk(WM_MESSAGE * pMsg) {
      101. switch (pMsg->MsgId) {
      102. case WM_PAINT:
      103. GUI_SetBkColor(GUI_BLACK);
      104. GUI_Clear();
      105. break;
      106. default:
      107. WM_DefaultProc(pMsg);
      108. break;
      109. }
      110. }
      111. /*********************************************************************
      112. *
      113. * Public code
      114. *
      115. **********************************************************************
      116. */
      117. /*********************************************************************
      118. *
      119. * MainTask
      120. */
      121. void MainTask(void) {
      122. WM_HWIN hSwipelist;
      123. WM_HWIN hItem;
      124. int i;
      125. char acBuffer[4];
      126. GUI_Init();
      127. WM_MULTIBUF_Enable(1);
      128. WM_SetCallback(WM_HBKWIN, _cbBk);
      129. hSwipelist = SWIPELIST_CreateEx(0, 0, 320, 240, WM_HBKWIN, WM_CF_SHOW, 0, GUI_ID_SWIPELIST0);
      130. WM_SetCallback(hSwipelist, _cbSwipeList);
      131. for (i = 0; i < NUM_BOXES; i++) {
      132. sprintf(acBuffer, "%i", i);
      133. SWIPELIST_AddItem(hSwipelist, acBuffer, 30);
      134. hItem = CHECKBOX_Create(0, 0, 20, 20, 0, ID_CHECKBOX_0 + i, WM_CF_SHOW | WM_CF_HASTRANS);
      135. WM_SetCallback(hItem, _cbCheckbox);
      136. SWIPELIST_ItemAttachWindow(hSwipelist, i, hItem, 160, 5);
      137. }
      138. while (1) {
      139. GUI_Delay(100);
      140. }
      141. }
      142. /*************************** End of file ****************************/
    • New
      Hi Seven. While creation Even I dont have any problem but problem is coming when suppose i am at 7th radio button position and at that time i have to delete and create the swipe list to refresh the screen but there i need to even retain the position i.e 7th radio button for that i am doing like this.
      if(SWIPELIST_GetNumItems(SwipeListHndl) > 3)
      Lvl2ScrollPos = SWIPELIST_GetScrollPos(SwipeListHndl); // take the scroll position before refreshing to stay in the same position after refresh
      GUI_EndDialog(g_SettWinHndl,DIALOG_RETURN_VAL);
      g_SettWinHndl = GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbSettingsDialog, g_SettMainWinHndl, 3, 32);
      WM_SetCreateFlags(WM_CF_MEMDEV);
      WM_EnableMemdev(g_SettWinHndl);
      SWIPELIST_SetScrollPos(SwipeListHndl,Lvl2ScrollPos);
      after this when screen is created that problem is coming that too when scroll position is below -245.
      Can you please try it whether it is happening same for you.
      Kusum
