STM32 and SEGGER RTT for printing debugging messages
    • STM32 and SEGGER RTT for printing debugging messages
      Hi, I'm using NUCLEO-F446RE (STM32F4 ARM® Cortex®-M4 MCU 32-Bit Embedded Evaluation Board), Keil MDK 5.20 on 64-bit Windows 10.
      digikey.com/product-detail/en/…46RE/497-15882-ND/5347712
      Instead of using the ST-Link, which is pre-installed on the NUCLEO-F446RE board, I used "Converting ST-LINK On-Board Into a J-Link".
      segger.com/products/debug-prob…j-links/st-link-on-board/
      Also, I use my custom J-Link Plus to connect the board to the PC.
      When printing debugging messages, I used STM32F4's UART pins.
      I wish to use the RTT to print these messages.
      - Is this STM32F446RE MCU able to use the RTT to print debugging messages?
      - If so, how can I do that when using Keil MDK? Hope to see any references (documents, examples, etc), please.
      Thanks for your help.
      -Best Regards, Matthew
    • Hello Matthew,
      Any Cortex-M can use RTT.
      But Keil MDK does not provide a RTT terminal to display the messages.
      For this you can either use the J-Link RTT Viewer software that comes with the J-Link software package or use our debug software Ozone instead.
      segger.com/products/development-tools/ozone-j-link-debugger/
      If you are looking for an IDE that supports RTT out of the box Embedded Studio can be used as well.
    • New
      Hi, Nino.
      Just like this screenshot, do you mean I can call
      1. SEGGER_RTT_TerminalOut
      when using the STM32 series and see the log message using Ozone, regardless of what IDE (Keil, SEGGER ES, IAR EWARM) I use?
      Also, in order to use the RTT, do I have to set the heap size of the STM32 microcontroller?
