Add a Custom USB Class
    • Add a Custom USB Class
      I'm trying to add the USB CCID Class to the Segger emUSB-Device (the device I'm using is the Dialog DA14683). However, it seems that the CCID Class is not included in the emUSB-Device library, so I'm attempting to implement it as a Custom USB Class.
      By the way, I'm not able to modify the USB descriptor in order to add a new class, through the USB Core. Is there a way to create and add a new USB Class to the emUSB?
      Best Regards
    • I assume you are using the Dialog SDK, which includes our stack in library form?
      A library can not be easily extended with a new class.
      In case of doubt please contact Dialog.
