[SOLVED] 5K monitor doesn't work with Segger embedded Studio
  • [SOLVED] 5K monitor doesn't work with Segger embedded Studio
    I recently changed to a 5K monitor and found that a one feature doesn't work with it.
    When I click the blue button to change from Release to Debug or the other way in full screen mode, it doesn't create the pop up necessary.
    When I drag SES down a bit, it magically works
    Is there any quick fix I can try?
    I am using a Macbook Pro with the most recent version of SES.
    Best,
    John
  • Also, if I right click a variable that is near the top of the panel,
    The pop up is created much below it.
    For example, in the screenshot, if I right click on app_error.h the pop up is generated much below it.
    This is not a critical issue as the original post but might be related to it.
    We will try to reproduce the reported behaviour and see if it can be improved.
