Code Formatting from Command Line
    • Code Formatting from Command Line
      Is there a way to invoke the "Edit/Format" command on a file from outside of SES? Is there a command line function (similar to emBuild) that can be used for this?
      I'd like to use the formatting feature on a regular basis on all the files in a solution, making clicking on the menu selection or using the keyboard shortcut on each individual file impractical.
      Russ
    • Hello Russ,
      Currently code formatting can only be triggered on a per file basis. There are no plans to expand this feature on solution basis or to make it available via command line.
