switch dialogbox
    • switch dialogbox
      Hi.
      Using a nested window in a project I made based on the following example gives an error.
      I want to enter the sub-menus by pressing the buttons.
      For example
      Settings(dialog1)-> Display(dialog2)- -> Resolution(dialog3)
      Settings(dialog1)--> Audio(dialog4)--> Device(dialog5)
      1. C Source Code
      2. #include "DIALOG.h"
      3. /*********************************************************************
      4. *
      5. * Externals
      6. *
      7. **********************************************************************
      8. */
      9. /*********************************************************************
      10. *
      11. * Defines
      12. *
      13. **********************************************************************
      14. */
      15. #define ID_WINDOW_00 (GUI_ID_USER + 0x00)
      16. #define ID_TEXT_00 (GUI_ID_USER + 0x01)
      17. #define ID_BUTTON_00 (GUI_ID_USER + 0x03)
      18. #define ID_WINDOW_10 (GUI_ID_USER + 0x00)
      19. #define ID_TEXT_10 (GUI_ID_USER + 0x01)
      20. #define ID_BUTTON_10 (GUI_ID_USER + 0x03)
      21. /*********************************************************************
      22. *
      23. * Static data
      24. *
      25. **********************************************************************
      26. */
      27. /*********************************************************************
      28. *
      29. * _aDialogCreate
      30. */
      31. static const GUI_WIDGET_CREATE_INFO _aDialogCreate0[] = {
      32. { WINDOW_CreateIndirect, "Window", ID_WINDOW_00, 0, 0, 320, 240, 0, 0x0, 0 },
      33. { TEXT_CreateIndirect, "Dialog 1", ID_TEXT_00, 100, 100, 120, 40, 0, 0x0, 0 },
      34. { BUTTON_CreateIndirect, "Switch", ID_BUTTON_00, 110, 170, 80, 20, 0, 0x0, 0 },
      35. };
      36. /*********************************************************************
      37. *
      38. * _aDialogCreate
      39. */
      40. static const GUI_WIDGET_CREATE_INFO _aDialogCreate1[] = {
      41. { WINDOW_CreateIndirect, "Window", ID_WINDOW_10, 0, 0, 320, 240, 0, 0x0, 0 },
      42. { TEXT_CreateIndirect, "Dialog 2", ID_TEXT_10, 100, 100, 120, 40, 0, 0x0, 0 },
      43. { BUTTON_CreateIndirect, "Switch", ID_BUTTON_10, 110, 170, 80, 20, 0, 0x0, 0 },
      44. };
      45. static WM_HWIN _hDialog0;
      46. static WM_HWIN _hDialog1;
      47. /*********************************************************************
      48. *
      49. * Static code
      50. *
      51. **********************************************************************
      52. */
      53. /*********************************************************************
      54. *
      55. * _cbDialog1
      56. */
      57. static void _cbDialog1(WM_MESSAGE * pMsg) {
      58. WM_HWIN hItem;
      59. int NCode;
      60. int Id;
      61. switch (pMsg->MsgId) {
      62. case WM_INIT_DIALOG:
      63. //
      64. // Initialization of 'Window'
      65. //
      66. hItem = pMsg->hWin;
      67. WINDOW_SetBkColor(hItem, GUI_MAKE_COLOR(0x00EFFFBF));
      68. //
      69. // Initialization of 'Dialog 1'
      70. //
      71. hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_10);
      72. TEXT_SetTextColor(hItem, GUI_MAKE_COLOR(0x00000000));
      73. TEXT_SetTextAlign(hItem, GUI_TA_HCENTER | GUI_TA_VCENTER);
      74. TEXT_SetFont(hItem, GUI_FONT_32B_1);
      75. break;
      76. case WM_NOTIFY_PARENT:
      77. Id = WM_GetId(pMsg->hWinSrc);
      78. NCode = pMsg->Data.v;
      79. switch(Id) {
      80. case ID_BUTTON_10: // Notifications sent by 'Switch'
      81. switch(NCode) {
      82. case WM_NOTIFICATION_RELEASED:
      83. WM_HideWindow(_hDialog1);
      84. WM_ShowWindow(_hDialog0);
      85. break;
      86. }
      87. break;
      88. }
      89. break;
      90. default:
      91. WM_DefaultProc(pMsg);
      92. break;
      93. }
      94. }
      95. /*********************************************************************
      96. *
      97. * _cbDialog0
      98. */
      99. static void _cbDialog0(WM_MESSAGE * pMsg) {
      100. WM_HWIN hItem;
      101. int NCode;
      102. int Id;
      103. switch (pMsg->MsgId) {
      104. case WM_INIT_DIALOG:
      105. //
      106. // Initialization of 'Window'
      107. //
      108. hItem = pMsg->hWin;
      109. WINDOW_SetBkColor(hItem, GUI_MAKE_COLOR(0x00100040));
      110. //
      111. // Initialization of 'Dialog 1'
      112. //
      113. hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_00);
      114. TEXT_SetTextColor(hItem, GUI_MAKE_COLOR(0x00FFFFFF));
      115. TEXT_SetTextAlign(hItem, GUI_TA_HCENTER | GUI_TA_VCENTER);
      116. TEXT_SetFont(hItem, GUI_FONT_32B_1);
      117. break;
      118. case WM_NOTIFY_PARENT:
      119. Id = WM_GetId(pMsg->hWinSrc);
      120. NCode = pMsg->Data.v;
      121. switch(Id) {
      122. case ID_BUTTON_00: // Notifications sent by 'Switch'
      123. switch(NCode) {
      124. case WM_NOTIFICATION_RELEASED:
      125. WM_HideWindow(_hDialog0);
      126. WM_ShowWindow(_hDialog1);
      127. break;
      128. }
      129. break;
      130. }
      131. break;
      132. default:
      133. WM_DefaultProc(pMsg);
      134. break;
      135. }
      136. }
      137. /*********************************************************************
      138. *
      139. * _cbBk
      140. */
      141. static void _cbBk(WM_MESSAGE * pMsg) {
      142. switch (pMsg->MsgId) {
      143. case WM_PAINT:
      144. GUI_SetBkColor(GUI_GRAY);
      145. GUI_Clear();
      146. break;
      147. default:
      148. WM_DefaultProc(pMsg);
      149. break;
      150. }
      151. }
      152. /*********************************************************************
      153. *
      154. * Public code
      155. *
      156. **********************************************************************
      157. */
      158. /*********************************************************************
      159. *
      160. * MainTask
      161. */
      162. void MainTask(void) {
      163. GUI_Init();
      164. WM_SetCallback(WM_HBKWIN, _cbBk);
      165. _hDialog0 = GUI_CreateDialogBox(_aDialogCreate0, GUI_COUNTOF(_aDialogCreate0), _cbDialog0, WM_HBKWIN, 0, 0);
      166. _hDialog1 = GUI_CreateDialogBox(_aDialogCreate1, GUI_COUNTOF(_aDialogCreate1), _cbDialog1, WM_HBKWIN, 0, 0);
      167. WM_HideWindow(_hDialog1);
      168. while (1) {
      169. GUI_Delay(100);
      170. }
      171. }
      What could be the problem?
      Hakan
    • I did a little experiment, the sample file is failing.
      I'm running the system, I touch the button a lot of times and the system crashes after a while.(I've touched the button without stopping, and I think it's crashing at the 20th touch)
      edit:Crashed after 1 minute.
      Hakan
      The post was edited 1 time, last by Hakan ().
