Path white space causing errors in emBuild
    • Path white space causing errors in emBuild
      New
      Hey Segger support and community, I'm trying to use emBuild to automate builds for a Nordic nRF52 project (SDK 15.0.0). The build fails due to white space in included file paths.
      Here's the environment I'm using:
      - MacOS 10.13.6
      - Segger Embedded Studio for Arm 3.34a
      - SEGGER Embedded Studio for ARM emBuild - Release 3.34a
      I successfully compile the project when using Segger Embedded studio. The build commands that it produces starts as follows, wrapping paths and options in quotes:
      "/Applications/SEGGER Embedded Studio for ARM 3.34a/gcc/arm-none-eabi/bin/cc1" ...
      When I run emBuild, quotes are not included around the path to the compiler or around options that include file paths. It results in an error.
      I've made some progress by specify the "studiodir" option with escape characters before the whitespace:
      Shell-Script
      1. emBuild -config Release -verbose -studiodir '/Applications/SEGGER\ Embedded\ Studio\ for\ ARM\ 3.34a' -echo /usr/local/nRF5_SDK_15.0.0_a53641a/examples/project/application/pca10040/s132/ses/projcet.emProject
      However, there's other include paths in the project that contain white space, and those cause further errors.
      For example, when I compile with Segger Embedded Studio, the following -isystem option is surrounded in quotes:
      "-isystem/Users/raykampmeier/Library/SEGGER/SEGGER Embedded Studio/v3/packages/include"
      When using emBuild, there are no quotes around this option, resulting in an error:
      Is there a way to have emBuild automatically wrap options in quotes? Or any suggestions for how to get around this?
      -Ray
