DMA frame buffer copy
    • DMA frame buffer copy
      In an effort to optimize my application, I am investigating DMA transfer for frame buffer copies. The "Multiple Buffering" chapter in the manual describes how to inform emWin to use a custom callback routine in LCD_X_Config():
      LCD_SetDevFunc(0, LCD_DEVFUNC_COPYBUFFER, (void (*)())_CopyBuffer);
      The problem I'm having with DMA implementation is how to notify emWin that the buffer copy is completed. Since emWin is not expecting _CopyBuffer() to return anything, I end up with one of the following scenarios:
      1. DMA transfer is started inside _CopyBuffer() and the function returns. emWin thinks upon return that the frame buffer copy is done, so I end up with the incorrect buffer being displayed (flipping between buffers which are obviously wrong). I am using triple buffering.
      2. I create a loop inside _CopyBuffer() which waits for the DMA transfer to complete. This is no benefit over a standard memcpy().
      Am I missing something simple or is this just not possible?
      emWin V5.38
      NXP LPC546xx
      You have to implement a VSYNC interrupt routine which tells emWin the back buffer has become the front buffer. Only setting a CopyBuffer function is not sufficient.
      Attached is a LCD configuration used for the LPC54608. Just use it a reference.
      • LCDConf.zip
        (2.61 kB, downloaded 243 times, last: )
