[SOLVED] Ozone and B-L072Z-LRWAN1 / STM32L072CZ
  • [SOLVED] Ozone and B-L072Z-LRWAN1 / STM32L072CZ
    I have a Board B-L072Z-LRWAN1 with an STM32L072CZ.
    I use Ozone V2.62 / 2019-04-09.
    I reflashed the ST-Link on the board, but only get:
    Debug.SetConnectMode (CM_DOWNLOAD_RESET);
    Debug.Start();
    Connection failed
    Is there any way to track the problems down any further?
    Does anybody use the LRWAN1 with Ozone successfully?
    EDIT:
    When I write that I reflashed the ST-Link, then this means I used the
    Segger tool to flash the alternative firmware that enables the use
    with Ozone. It seems the board is not supported by that SW and I
    think I have bricked my B-L072Z-LRWAN1. My fault, clear.
    If there is any way to fix this it would be great.
    Torsten
    The post was edited 1 time, last by tmohr ().
  • Hello Torsten,
    The mentioned board should be compatible to the J-Link FW:
    segger.com/products/debug-prob…j-links/st-link-on-board/
    To verify functionality could you try using J-Link Commander and check if general connection to the target device is working?
    Could you post a screenshot of such a session?
  • Hello Nino,
    Thanks for your help. Correct, the board should be supported.
    Please see the screenshot attached.
    It seems to fail on a very low level. It is the same result for both boards I have (STM32L072CZ).
    The standard program that is on the STM32L072CZ is still running as expected.
    The green LED in the STLINK part is blinking with approx. 5-10 Hz.
    I updated at least three STM32F407 Discovery the same way and they all work as expected.
    I have a normal standard J-Link, maybe I can use that one to reflash the standard ST-Link SW or the J-Link SW?
    Torsten
  • Hello Torsten,
    It seems like there is a generic USB issue with the converted ST-Link and the Linux version you are using.
    Which version are you using?
    Is it native or in a VM?
    Do you have another PC to test against?
  • Hello Nino,
    I use openSUSE Leap 42.3.
    I debugged several STM32F407 Discovery on the same PC and OpenSuse installation.
    I can try another PC, but that may take some time. It will be a Windows 10 Laptop.
    Torsten
    I just installed and tried the latest JLink on a MacBook.
    I get the same result as on Linux:
    tmohr ~ $ /Applications/SEGGER/JLink_V644h/JLinkExe ; exit;
    SEGGER J-Link Commander V6.44h (Compiled May 3 2019 17:40:43)
    DLL version V6.44h, compiled May 3 2019 17:40:32
    Connecting to J-Link via USB...FAILED: Cannot connect to J-Link via USB.
    I also tried connecting to the LRWAN1 with an older version of Ozone on a Windows 10 PC but don't have a screenshot or log.
    Also there, the board is not found. It offers me to open an IP connection to debug.
    As I can debug the STM32F407 Discovery I rather think something went wrong with the update process.
    Do you think I can refresh the debug chip on the board somehow? I have a real JLink that I could use for that or the debugger part of an STM32F407 Discovery.
    Torsten
  • Hello Torsten,
    Generally when starting the Reflash utility you also get an option to restore the ST-Link.
    So we suggest to try that and then refnash it again to J-Link.
    It is possible that you might need a ST-Link image for restoring the device. In that case we suggest requesting such image directly at ST.
