I am using Segger J-Link Ultra+ debugger under GNU/Linux and I am facing some problems with "
J-Link Software and Documentation pack for Linux, TGZ archive, 64-bit" software package.
Sometimes when I'm trying to run for example JLinkExe application I get following error:
# ./JLinkExe
SEGGER J-Link Commander V6.44g (Compiled Apr 18 2019 17:15:12)
Could not open J-Link shared library. Exiting now.
I noticed that this error occurs always after I run "ldconfig" Linux command.
After run this (ldconfig) command I get another error:
ldconfig: libraries libjlinkarm.so.6 and libjlinkarm_x86.so in directory /usr/local/JLink_Linux_V644g_x86_64 have same soname but different type.
ldconfig: libraries libjlinkarm_x86.so and libjlinkarm_x86.so.6.44.7 in directory /usr/local/JLink_Linux_V644g_x86_64 have same soname but different type.
Seems like the libjlinkarm_x86.so.6.44.7 library is not properly build during linking process, because:
$ objdump -p libjlinkarm.so.6.44.7 | grep SONAME
SONAME libjlinkarm.so.6
$ objdump -p libjlinkarm_x86.so.6.44.7 | grep SONAME
As far as I know these libraries needs to have different sonames but they are the same. Probably "-soname" option of "ld" linker will help with this problem during linking process.
# ./JLinkExe
