[SOLVED] J-Link + STM32F4 + Atollic: ERROR: Can not read register [...] while CPU is running
  • [SOLVED] J-Link + STM32F4 + Atollic: ERROR: Can not read register [...] while CPU is running
    Hi everyone,
    I am running j-link base with latest firmware (2019 Mar 21) to debug STM32F415RG, using Atollic TrueSTUDIO ver 9.1.0 (Eclipse Neon).
    Sometimes the debug session runs with no problems, but most of a time a get an error when I try to run the session using "Resume". When I use "Step Over" or "Step Into" it always works fine. Here is an Console output of debug session init:
    1. SEGGER J-Link GDB Server V6.44 Command Line Version
    2. JLinkARM.dll V6.44 (DLL compiled Mar 1 2019 17:32:34)
    3. Command line: -port 2331 -s -CPU Cortex-M -device STM32F415RG -endian little -speed 4000 -if swd -vd
    4. -----GDB Server start settings-----
    5. GDBInit file: none
    6. GDB Server Listening port: 2331
    7. SWO raw output listening port: 2332
    8. Terminal I/O port: 2333
    9. Accept remote connection: localhost only
    10. Generate logfile: off
    11. Verify download: on
    12. Init regs on start: off
    13. Silent mode: off
    14. Single run mode: on
    15. Target connection timeout: 0 ms
    16. ------J-Link related settings------
    17. J-Link Host interface: USB
    18. J-Link script: none
    19. J-Link settings file: none
    20. ------Target related settings------
    21. Target device: STM32F415RG
    22. Target interface: SWD
    23. Target interface speed: 4000kHz
    24. Target endian: little
    25. Connecting to J-Link...
    26. J-Link is connected.
    27. Firmware: J-Link V10 compiled Mar 21 2019 15:43:57
    28. Hardware: V10.10
    29. S/N: 50121268
    30. Feature(s): GDB
    31. Checking target voltage...
    32. Target voltage: 3.30 V
    33. Listening on TCP/IP port 2331
    34. Connecting to target...Connected to target
    35. Waiting for GDB connection...Connected to 127.0.0.1
    36. Reading all registers
    37. Read 4 bytes @ address 0x08000DF0 (Data = 0xBF00E7FE)
    38. Connected to 127.0.0.1
    39. Reading all registers
    40. Read 4 bytes @ address 0x08000DF0 (Data = 0xBF00E7FE)
    41. Received monitor command: WriteDP 0x2 0x000000F0
    42. O.K.
    43. Received monitor command: ReadAP 0x2
    44. O.K.:0xE00FF003
    45. Reading 32 bytes @ address 0xE00FFFD0
    46. Read 2 bytes @ address 0x08000DC0 (Data = 0xB508)
    47. Received monitor command: speed 30
    48. Target interface speed set to 30 kHz
    49. Received monitor command: endian little
    50. Target endianess set to "little endian"
    51. Received monitor command: reset
    52. Resetting target
    53. Received monitor command: speed auto
    54. Select auto target interface speed (2000 kHz)
    55. Received monitor command: flash download = 1
    56. Flash download enabled
    57. [...]
    As soon as I hit the "Resume" button the console outputs ERRORs and the debug process can not be paused or braked:
    1. [...]
    2. ERROR: Can not read register 64 (FPS31) while CPU is running
    3. WARNING: Failed to read memory @ address 0xDEADBEEE
    4. Starting target CPU...
    5. ERROR: CPU is not halted
    6. ERROR: Can not read register 15 (R15) while CPU is running
    7. Reading all registers
    8. ERROR: Can not read register 0 (R0) while CPU is running
    9. ERROR: Can not read register 1 (R1) while CPU is running
    10. ERROR: Can not read register 2 (R2) while CPU is running
    11. ERROR: Can not read register 3 (R3) while CPU is running
    12. ERROR: Can not read register 4 (R4) while CPU is running
    13. ERROR: Can not read register 5 (R5) while CPU is running
    14. [...]
    I tried using Ozone V2.62a for debugging the same code and I get similar results. Step-by-step debug goes fine, bus as I hit resume: "Failed to read target status. Abort Debug Session?"
    1. Debug.Continue();
    2. J-Link: connection to target device lost.
    3. Debug.Halt();
    4. CPU could not be halted
    I have tried to simulate condition when I starts to work fine or the moment it breaks, but with no luck. Resetting hardware, j-link, eclipse, number of breakpoints etc...
    Did anyone experienced similar issue? Can it be a hardware problem? Faulty j-link?
    Regards:
    - Tomasz
    I have just tried using ST-Link just a moment ago and it works flawlessly.
    Weird thing is that J-Link started working after using ST-Link, but I have been here before...I get to work and at some point I get the same behaviour as above.
    Earlier I also tested deleting the debug configuration in Atollic, or a clean build, but none of it fixed the problem.
    - Tomasz
  • Hello Tomasz,
    The reported behaviour sounds like it might be application specific.
    Is the behaviour reproducible with any application?
    Could you provide a J-Link log of the failing session?
    Does your application enable any sleep modes or uses WFI/WFE calls?
  • Hi Nino!
    Today it came out that it was application specific and it was my mistake. Certain operation caused system under-voltage and MCU was acting not predictably. At some point it stopped working even with the ST-Link, so it was a lead to investigate further. Additional power filtration fixed the problem.
    In the end it was not a J-Link problem, just my bad design.
    Thank you for everybody help.
    Regards:
    - Tomasz
  • Hello Tomasz,
