it seems that there is problem with NXP MKL28Z512xxx7 support in software v6.44f. I'm unable to connect neither with J-Link EDU nor with onboard OpenSDA (Segger firmware). J-Flash Lite says "ERROR: Could not connect to target.", Ozone is little more specific:
Device "MKL28Z512XXX7" selected.
InitTarget()
Connect Under Reset
Communication error while accessing MDM-AP.
Connect Under Reset
InitTarget()
Connect Under Reset
Connect Under Reset
InitTarget(): PCode returned with error code -1
InitTarget()
Connect Under Reset
Connect Under Reset
InitTarget()
Connect Under Reset
Connect Under Reset
Connection failed
Tested with multiple FRDM-KL28Z boards, always the same results. Please, can you check this issue? Thank you.
Best regards, Martin
InitTarget()
Connect Under Reset
Connect Under Reset
InitTarget()
Connect Under Reset
Connect Under Reset
InitTarget()
Connect Under Reset
Connect Under Reset
InitTarget()
Connect Under Reset
Connect Under Reset
Connection failed
