[SOLVED] J-Scope and IAR elf output (.out)
  • [SOLVED] J-Scope and IAR elf output (.out)
    Hi
    I am trying to use J-Scope (V5.10d) with an .elf file generated using IAR EWARM V8.32.4, it is actually an .out file.
    When using the New Project Wizard, after selecting the .elf file, the program crashes.
    Does J-Scope support the elf format generated by IAR EWARM?
    Gawie
    We received your inquiry via our Supportsystem as well. To make sure no information is lost via multiple communication channels this thread will be closed now and further communication will be done via Supportsystem.
    Generally J-Scope should be capable of understanding EWARM elf files if the elf file contains symbol information.
