embUSB-Host with STM32F407VET6 example working good! (Keyboard)
    • embUSB-Host with STM32F407VET6 example working good! (Keyboard)
      I have ported (if I may say so) the usbHost example to STM32F407VE controller but I have some questions.
      1. I don't understand where is setting RCC in your example Trial_STM32F746_DISCO_USBH_HID_SES?
      I was forced to add SystemClock_Config(); at begin of main.c from like Keil example.
      After this changes my project with STM32F407VET6 start to run GOOD.
      Thank all! :)
      The post was edited 4 times, last by kkmspb: 2 Question is resolved via clear porting to STM32F407VET6 ().
    • In that project the RCC settings are done inside the SystemInit() function in the system_stm32f7xx.c file.
      The RCC settings for the USB controllers are done in the function _InitUSBHw() of the respective config file (USBH_Config_STM32F7xxFS_ST_STM32F746G_Discovery.c or USBH_Config_STM32F7xxHS_ST_STM32F746G_Discovery.c).
      BTW: I have read your russian guide on creating a first project with ES on the LPC1768, it is very good. Thank you, great job.
    • STM32F446 should be similar to the other STM32F4xx MCUs.
      emUSB-Host always requires an RTOS, that is correct.
    • The connector on the second one looks like regular mini-b, so it probably can not be used as a host.
      With the first board you can use a regular micro OTG adapter.
    • Ok, we started testing on the first board and see some strange results with a full speed hub.
      This likely is because of our errors or electric problems. But may I ask,
      is the demo version of the usb host library crippled in any way, such as error handling disabled?
      -- dd
    • ddbug wrote:
      But may I ask, is the demo version of the usb host library crippled in any way, such as error handling disabled?
      -- dd
      No, it is not crippled in any way.
      Are you using the debug version? The terminal output is disabled in the release version.
      Furthermore, is was USBH_ConfigSupportExternalHubs called inside USBH_X_Config with the parameter set to 1?
    • Thank you Yan. USBH_ConfigSupportExternalHubs is called, and hub works, but not stable.
      We need this thing to work against a KVM that has internal hub.
      The KVM often switches back and forth, every time the hub and all devices behind it re-enumerate.
      The problem can be caused by hardware. I'll check better later.
      -- dd
