ES Global macros
    • ES Global macros
      New
      Hi
      I am having similar issues with SES
      If I create a macro ROOT=c: in the build options at project level,
      then define
      $(ROOT)\NixInclude in the user includes
      The header files in that directory are not found...
      user includes "say" they will use macro expansion.
      But the exported build for the offending source file simply has
      -I$(ROOT)\NixInclude
      - not the macro-expanded version
      I have tried these at all levels, from solution down to individual source file, and cannot seem to figure it out.
      Probably just a syntax error on my part, but I want to get this sorted so I can switch SDK versions between projects by over-riding the root path.
      Any ideas?
    • New
      -- Moved to new thread as it was unrelated to other inquiry--
      Try forward slashes when setting paths, that should make it work.
