SystemView reset board on each starting loading.
    • New
      What target device are you debugging exactly?
      How is your setup? Do you run SystemView standalone or in parallel to a debug session in an IDE?
    • New
      Hi Nino, thank you for your replay.
      Did not get you, what did you mean by "How is your setup?"
      The target is ATSAME70Q21, I've tried to run it standalone as well as in parallel with debug session; result is the same. The same setup with other targets runs as expected (stm32f407 and others M4).
