[SOLVED] Can't program RZA1H custom board
  • [SOLVED] Can't program RZA1H custom board
    The J-Link Lite included with Renesas RSK board works fine to program the on-board QSPI flash devices. I used the JLink commander version V634h.
    It doesn't seem to work when tried to program a custom board that was designed with the same controller device RZA1H as in RSK board.
    The custom board differ in the following:
    (1) It uses a different QSPI flash (S25FL512S) but supported by JLink program.
    (2) It configures SPBIO port 1 as follows (SPBIO port 0 is the same)
    SPBIO01 P8_14
    SPBIO11 P8_16
    SPBIO21 P9_0
    SPBIO31 P9_1
    Do I need notify the JLink commander (say by command line option) the custom change in the configuration.
    Can Jlink identify the ports to which the QSPI devices connected to for automatic programming, as there are only couple combinations available in the device?
    Thanks in advance
    EsKay
  • Hello EsKay,
    The Flashloader that comes with J-Link software for the QSPI for that Chip works only with exactly the pins that are used on the eval board.
    If you are using other pins it will not work.
    So you would need to adjust the Flash loader to fit your used pins. The Flash loader can be requested using our official support channel.
    For more information see my signature.
