Can't program RZA1H custom board
    • Can't program RZA1H custom board
      The J-Link Lite included with Renesas RSK board works fine to program the on-board QSPI flash devices. I used the JLink commander version V634h.
      It doesn't seem to work when tried to program a custom board that was designed with the same controller device RZA1H as in RSK board.
      The custom board differ in the following:
      (1) It uses a different QSPI flash (S25FL512S) but supported by JLink program.
      (2) It configures SPBIO port 1 as follows (SPBIO port 0 is the same)
      SPBIO01 P8_14
      SPBIO11 P8_16
      SPBIO21 P9_0
      SPBIO31 P9_1
      Do I need notify the JLink commander (say by command line option) the custom change in the configuration.
      Can Jlink identify the ports to which the QSPI devices connected to for automatic programming, as there are only couple combinations available in the device?
      Thanks in advance
      EsKay
